sim tray eject mechanism
I am referring to step 23 in the ifixit tear-down.
iPhone 3G Rear Case Replacement
On reassembly in my new case, i found that i did not have a hole for this screw, obviously this felt like a kick in the nuts and it took me hours of trying before i decided to heat up a pin and make a hole.
my question is; has anyone else had this problem and what solution did you use?
Do let us know where did you purchase the case, so others can avoid getting into the same situation. Thanks!
由 riDerz 完成的
The case was purchased off a seller from hong kong on ebay, i have bought the same item from different ebayers from hong kong since and they were fine- just keep in mind you get what you pay for; £2.99 may not be good.
由 peter 完成的
