跳转到主内容
Model number TF700T released in July 2012. The Asus Transformer Pad Infinity is a Wi-Fi and Bluetooth capable tablet with a 10.1 inch screen and 8MP camera.
11 个问题 查看全部
问题已关闭
USB Charger Dock port broken
The charger port where the usb charger is connected is broken in my transformer infinity. my local repair center is unable to get a new part. if I have to repair it my self, what parts do I need? can anyone suggest the part number of the charger port and where I can order it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Ishu,
You need the docking ribbon cable. The connector is attached to it.
There are different versions out there, and I only found a company in Europe. Look at this here (under "Cable"). Here is such a cable for a TF300, just to show you how it looks like.
You also might want to google for a company in US that sells it.
Steffen
这个答案有帮助吗?
得分 1
3条评论:
Thank you for your suggestion.
There are so many cables to choose from and most of them are compatible with TF700T. Just to confirm is this ("TF700K DOCKING FPC R1.6, Part number 08301-00206100") the one that I should be using, or can I use any of them.
完成的
Hi Ishu, honestly I am not sure which one to choose. But considering the different revisions, yes, I would go with the one you mentioned (latest version). However, if you want to be 100% sure, just give them a call or send them an email for clarification before you buy the cable.
完成的
Hello Steffen
Thanks a lot for your help. much appreciated. will give it a try.
完成的
添加一条评论
can the port on a asus tablet be repaired or his there other adapters that will work
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,281
