跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Function interconnect cables iPhone 5
By accident I broke one of my interconnect cables:
Picture:
http://d3nevzfk7ii3be.cloudfront.net/igi...
After reassembling, everything seems to work. What are the functions of the upper and lower interconnect cables in the iPhone 5?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
最有帮助的答案
The straight one is for cellular diversity. Faulty one impacts cellular reception and download speed.
The one with 2 turns is GPS interconnect. Without this the navigation will not work
These two do not have anything to do with wifi at all
这个答案有帮助吗?
得分 9
添加一条评论
hi
its a Interconnect Cable for antenna probably you can face some issues with reception of cellular or wifi signals.
also you can have a look the this link
it shows how to install a new one if yours iphone has a broken one now.
If you think i answered your question please rate (score) and mark it accepted. :)
Thanks
这个答案有帮助吗?
得分 2
添加一条评论
What if the 2 turns break down? Will it show sign of No SIM even though I had insert a SIM card?
这个答案有帮助吗?
得分 0
添加一条评论
Jayson make sure you time and date is correct then put in airplane mode for 10 seconds and it should recognise sim
这个答案有帮助吗?
得分 0
添加一条评论
* The straight cable is related to cell signal strength. [Such as No SIM/No Service]
  • The angled cable is related to GPS signal strength. [For Map]'''
这个答案有帮助吗?
得分 0
添加一条评论
I broke straight cable's head when I tried to push it up. But after all wifi signal is working as well as cellular signal. At first, iPhone shuts down every minute. Then I decided to shut it off for few minutes and try back on. As I do, it works fine. I don't know what the problem is. There must be something else.
这个答案有帮助吗?
得分 0
1条评论:
That's just for cellular diversity, you lose some reception and cellular download speed, that's all.
完成的
添加一条评论
添加你的答案
iPhone Guru 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 12,700
