跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
Error 1604 during jailbreak?
My cousin gave me a 16 gb iPod touch 1st gen and I decided to jailbreak it (before I fixed the screen) and I used whited00r 6. Everything was working until the end of the installation where itunes opened a window that said: error 1604. I tried again in a different port because that's what it told me to do. same thing happened again and I ended up having to wipe it (nothing of value was on it anymore).
Should I use another system to jailbreak it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Ted Mayer, go through the steps systematically:"Method 1:
Try changing USB ports.
Try using a different dock connector to USB cable.
Make sure that you are using the actual USB or the original.te
Try connect directly to the white Apple USB dock connector cable.
Try update your iTunes to the latest one.
If the issue still appears try method 2
Method 2 :
1- Connect the device to iTunes, then put your device in Recovery Mode. using the steps below
Connect your USB cable into your computer.
Turn your iPhone off by holding the power button down until you see “slide to power off”.
Now hold the Home button while reconnecting the USB cable to your iPhone. After iPhone is connected it should power on the device.
Continue holding the Home button, you will see the Apple logo appear and then finally a “Connect to iTunes” will be displayed, now is the time to release the Home button.
2- Restore and wait for the error using the guide posted here
Method 3 :
For iPhone 3G, 2G and iPod Touch 1G, iPod Touch 2G users running OS 3.1.2 can use iREB to fix error 16xx or 29:
1- Download iREB and Start iTunes.
2- Put your iPhone into DFU mode.
Hold down power button and home button both at the same time for 10 seconds
After the 10 seconds release the power button and still pressing on the home button for another 10 seconds
3- Now close iTunes and Start iREB on your PC.
4- Select your device and wait for a few seconds till you get white or a red screen on your iPhone.
5- Open iTunes then press and hold left “alt” button on Mac or “Shift” button on Windows on the keyboard and then click on “Restore” button in the iTunes. Select a custom firmware .iPSW file and restore it. (note: this method doesn’t require a jailbroken devices)
Method 4 :
How To Fix iTunes Error 1600, 1601, 1602
if the above steps don’t solve your issue try to resolve it by disabling, deactivating, or uninstalling third-party security, antivirus, and firewall software on your computer." from here. I have had some good results with iReb, but have had the 16xx error with a bad battery as well. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
4条评论:
I'm not using the original connector, I'm using one I got at Walgreens because my cousin kept the connector for his iPhone 4s.
完成的
I want at least IOS 4. I have some friends that have jailbroken all the i-devices (iPhone, iPad, and iPod touch) before should I have them do it?
完成的
used whited00r 6 on 2 comps (mac and pc) and still didn't work. I got the connector back and tried again and still didn't work. I'll just have a friend do this.
What does cydia do?
完成的
I have a iMac running is 10.7 I think everything is up to date. Should I try on a older version of iTunes?
完成的
添加一条评论
Maby try using tinyumbrella? http://howtofixstuff.blogspot.ca/2013/09...
这个答案有帮助吗?
得分 0
添加一条评论
Whited00r 7 requries ios 3.1.2 of 3.1.3 Plese make sure that you are running a supproted version of ios then try ireb and whitedoor 7
I did it it works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ted Mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,985
