跳转到主内容
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
30 个问题 查看全部
The strap holder is loose
The strap holder where the ring goes is loose, how can I tighten it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Depending on the side you may only need to take the top cover off.
To do that remove the Philips screws around the lens flange (4) to remove the front cover. Then locate the two screws under it holding the top cover and then take the screws around the edge of the cover off (6 total). Then carefully lift the cover off {there could be a wire still attached}.
Use a small dab of nail polish on the lug screw threads to prevent it from loosing up again.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Leo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,208
