跳转到主内容
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 个问题 查看全部
Can I fix charging port?
I dropped my tablet on it's corner. The screen didn't break and everything works fine but it won't charge now. Can I replace the charging port, should I pay someone else to, or should I just watch for a replacement tablet?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
评论:
where would you order the part from?
完成的
添加一条评论
4个答案
You can def change the charging port. I think it is soldered directly to the board so a skilled person would need to do the job.
这个答案有帮助吗?
得分 0
添加一条评论
When I plug sync cable in for charging my Tab 2 will not turn on. It just shows a picture of the battery where it is trying to charge then the screen just go blank. As long as i have the cord pluged in it goes off and on the whole time.
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem ^
这个答案有帮助吗?
得分 0
添加一条评论
My charger cable was wet and i plugged my tab in to charge. can i just change the port on my tab? Wil that fix the problem because my tab does not switch on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 10,406
