跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Where is the accelerometer located
The accelerometer stopped working.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
are you sure its not a setting's issue ?
完成的
Yes I'm sure.
完成的
添加一条评论
1个答案
已选择的解决方案
Brett Turner, U205 on the image is the accelerometer.
Hope this helps, good luck.
Additional Info
Abnormal Acceleration,Gyro Sensor part
Check the Voltage
C238 = 2.8V
C239 = 2.8V
C237 = 1.8V
If No then Resolder U205 or REflow U500
If Yes
Check the Voltage
R460 = 1.8V
R461 = 1.8V
If No Resolder U500 or Reflow UCP400
If Yes
Acceleration,Gyro Sensor operate correctly?
If No REflow or Replace U205 using a Heatgun or change Logic board.
The resistors and capacitors are marked on the second image, including the schematic of where to measure. Again, hope this helps.
这个答案有帮助吗?
得分 2
2条评论:
Thank you. Now I'm thinking it's a software issue because it looks fine. ofcourse I can't see inside it.
完成的
Do you have a multimeter? There are a few things you can check. It's a bit tricky but not impossible. You will also have to know how to read a schematic.
完成的
添加一条评论
添加你的答案
Brett Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,844
