MacBook Pro 13' randomly shut down while in use
While using my MacBook it just randomly shut down- the screen went blank. I tried pressing the power button but nothing has changed.
It was fitted with a new battery and other parts back in December 2012- due to a water spilling incident but that was fully repaired at a high cost by apple.
It's only 6months old
Someone please help me?? :(
2条评论
I have an MBP 15" that acts very much the same way. At first I thought it might be a software problem but, after a reinstall of OS X it behaved the same. Upon opening it I discovered corrosion on the motherboard in several places. I cleaned it as best I could but it still acts the same and I will likely need to replace the motherboard.
Apple has cleverly put liquid damage detection stickers in various places on the motherboard and battery. All stickers were fine except one so somehow in the past liquid got in there. Since you know your machine had water damage, do you know if Apple repaired or replaced the motherboard? Do you know if they replaced anything else?
I suggest opening it up again and inspecting the motherboard and other parts for damage with magnifying glasses. I'll bet you discover corrosion on or around some surface components.
Good luck!
由 JohnV 完成的
Liquid damage is not a covered repair. JohnV- For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the O.Q. or Answer.
由 originalmachead 完成的
