跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
iPhone 4 won't recognize charger, even after replacing dock connector
Over the past two weeks, my Iphone has been having issues not recognizing the charging cable or dock when plugged in. I started to get the "Charging is not supported with this accessory" message when plugged in to the wall, followed shortly thereafter by the phone not charging when plugged in. The phone is dead now. I tried different cables, different wall adapters, car chargers, and docks all with no luck. I did a little research and found out that the dock connector could have gone bad due to moisture or wear and tear from 3rd party docks. I ordered a new dock connector and installed it by following the how-to on ifixit.com. The phone still doesn't recognize chargers or docks.
I'm not sure if it is a battery issue, because I can still hold the power button down and get the screen showing the emtpy battery with the plug + lightning bolt below it. This leads me to believe that there is still enough juice to power up the screen, so it's not completely drained. Battery life before this problem was average for a 2 year old Iphone 4.
I guess my next course of action will be to try to exchange the new dock connector for another new one to verify it wasn't a faulty part. If that doesn't work I am leaning toward replacing the battery, but I'm not sure if there is anything else I could be looking for.
Does anyone have any advice or ideas about what else could be causing the phone to not recognize the charger when plugged in?
Thanks in advance!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
My daughter's phone just started doing the same thing. Any luck with this issue. Don't know if I should replace battery or the port.
完成的
I have the EXACT same problem as you Doug. I'm also confused by iwillfix's comment. How can you test the charging dock by "just plugging it in". Were you able to fix your phone and if so, how?
完成的
Daniel I did end up changing the charger port. There were a few pins inside that was messed up.
Doug
完成的
添加一条评论
2个答案
最有帮助的答案
i would also try a new dock connector first (dont install, just plug it in). if it still doesn't charge replace the battery...
这个答案有帮助吗?
得分 1
添加一条评论
I have heard that you just need a new battery, try replacing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
efalese 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 3,895
