跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
iPhone shows dead battery screen after replacing the battery.
I've already been charging it for 2 hours, but the phone still shows a dead battery screen (a red battery with a bolt underneath). I followed the instructions on this site and I'm pretty sure I connected every ribbon back correctly. How can I fix this issue? Do I just have to wait, leave it overnight or should I put the old battery back in the iPhone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
I had the same symptoms as you are having. A replacement battery solved my problem. At power up, the battery screen showed 1/3 charged, so you may have a bad battery or you may need a new dock connector. Also make sure connector #4 is securely connected. I had to put some tape on the top to make sure the connector stayed down.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 424
