跳转到主内容
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 个问题 查看全部
问题已关闭
My computer displays "Failed to create E:\sdv.flg error" what to do?
I tried to reboot my computer and when I used the first install disk from HP, after about 4% of it being complete a message pops up saying "Failed to create E:\sdv.flg error". I was wondering what the issue is and how to fix it. The computer is less than a year old and tech support was no help from HP. I was on hold while they tried to figure out what was happening for 45mins and came up with nothing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like you are trying to restore the operating system from the restore cd. Is this correct?
Possible cause of failure durring the OS restore could be a scratched or dirty cd, bad RAM or bad hard drive.
Double check the CD that it is clean and has no scratches.
To test for bad RAM and hard drive I believe there is a test inside the BIOS, which you can access by pressing the proper key right after turning on the computer.
If there isn't a tool to test RAM and hard drive in the BIOS, if you have access to another computer, you can find download and burn the Ultimate Boot CD, which has a RAM (Memory) test, and hard drive test.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 482
