跳转到主内容
加入维修社区 - 创建账户
型号 A1369,1.6、1.7 或 1.8 GHz 处理器,64、128 或 256GB 闪存存储
Backlight not working after wine spill!
Hello,
After a wine spill on a 2011 Macbook air (A1369 EMC 2469) the backlight isn't working anymore.
The MacBook works fine, lcd is still functioning. Connected to a external display it also works fine, so it is probally not the graphic chip.
Did some research online, and found some hits about the fuse.
Does anyone have documentation about this fuse or what the problem could be.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi
Did you need a new logic board in the end??
any advice for similar problem?
由完成的
Gav - You should post your own question as your details could be different enough to require a different answer. Use this question as a template on what is needed. Clearly a good set of pictures helps!
由完成的
添加一条评论
3个答案
已选择的解决方案
Check the LVDS cable connector and the LVDS socket for any damage then also verify with a multimeter if the backlight fuse has continuity.
这个答案有帮助吗?
得分 1
4条评论:
Where can i find the backlight fuse?
由完成的
Sorry for the many comments, but on the last picture is this the fuse? with the P on it.
Multimeter gives me no continuity, so its blown.
由完成的
Your logic board is in bad shape: LVDS socket and backlight fuse are damaged and we don't know yet about the led driver. You have three choices: replace the logic board, find a repair shop that has the tools, parts and expertise to replace the damaged components or use the machine as a desktop machine with an external monitor.
由完成的
添加一条评论
最有帮助的答案
Before you worry about any fuses did you fully clean the wine out of the system? Make sure the right corner hinge area is clean (were the display is connected to the logic board)
这个答案有帮助吗?
得分 1
2条评论:
Logicboard seems to be clean, will take it out and will clean the other side too.
由完成的
Your pics show a lot of burn damage on the logic bd and the LVDS connector. The traces maybe damaged beyond repair here. As Lemerise stated below your likely going to need a new logic board. Sorry guy ;-{
由完成的
添加一条评论
tonversteeg1, yes the "P" is a fuse. Your display connector appears to show a lot of damage, so you may have to repair the connector as well as the circuit to it. That may be the reason for you bad fuse as well. The fuse is a 2AMP-32V 0402-HF and for more information on the fuse, check on here http://elcodis.com/parts/117249/0435002K...
这个答案有帮助吗?
得分 0
3条评论:
I agree with oldturkey, the P ic is the backlight fuse. Both the LVDS socket and connector are damaged et must be replaced. There's also a possibility of a LED DRIVER damage.
由完成的
Ok, thanks for comments.
Will order a new LVDS connector and a LVDS cable.
Only need to find someone who can do the job.
Does this Macbook pro LVDS connector also work?
http://www.ebay.nl/itm/Brand-New-MacBook...
由完成的
I would contact ebay sellers who advertise the LVDS connectors and ask them if they have your MBA connector in stock. The backlight fuse may be available online at http://www.digikey.com but I don't know your MBA fuse specs...sorry.
由完成的
添加一条评论
添加你的答案
tonversteeg1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 30
总计 11,026
