跳转到主内容
Released in October 2011. GoPro's second generation outdoor camcorder used by professional athletes, sports enthusiasts, and core enthusiasts.
19 个问题 查看全部
Wont turn on, contact issue?
Hello my HD Hero wont turn on, I got only for 1 second an black LCD Screen not more.
Now I open it, and I see something thats my the issue.
Please look to the Picture is an issue with an inductor, is this may the failure?
Picture Motherboard
Ciao
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
xen, yes it is easily possible that this what is giving you trouble. Checking your images, it appears to be a 2R2 power choke coil. That would make it a inductance code : 2R2 = 2.2uH SMD coil. It is readily available at places like this. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
hello,
you are right it is an 2r2 smd coil...! Is there any solution how I can test this coil before I try to exchange it?
Have a nice day.
完成的
xen, unless you have an inductance meter, the only thing you can test is a go-no go situation. If you have an analog meter, set it X1 ohm and place the probes across the small coil. The meter should show some reading and thus continuity. All that will show, however, is that the winding is okay.
完成的
添加一条评论
添加你的答案
xen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,391
