跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Why is my cable not connecting to the correct connector?
My Mac Mini 2012 hard drive flex cable plugs into the right connector while most of the Mac Mini 2012 I saw on net including iFixit, plugs into the left connector. This makes it impossible to use 2nd drive replacement kit cable because it also plugs into the right connector. It seems like Apple had a different version of the Mac Mini 2012, my Mac Mini part number is MD387ZP/A. I can send a picture to describe it better.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
It sounds like the cable may not be folded properly, as it should fit just fine into the left socket. If that isn't able to fix the issue, you may want to contact the company you got that cable from.
Update
Thanks. The problem starts with the original hard drive flex cable (not the 2nd drive kit cable). The original cable that I saw so far on the internet connects to left connector, however, when I open my mac (brand new not refurbished), it is connected to the right connector. This causes conflict because the 2nd drive kit cable (ifixit and Oxx) also connects to the right connector. My question is whether other experience the same thing and Apple actually made a design revision on the 2012 mac mini.
这个答案有帮助吗?
得分 1
1条评论:
I too am having this problem. I just opened up my Brand New Mini to use the Dual Drive kit, and found that Apple has apparently switched hard drive locations to the lower bay, and the original drive is connected now to the right logic board connector. Was this done to render kits like this obsolete? This totally sucks, as there doesn't seem to be a way to secure a second drive in the vacant location, and the ribbon cable supplied by iFixit won't work anyway.
完成的
添加一条评论
So you can still make it work. Having the vacant bay be the one closer to the access panel actually makes it easier to install a second drive, as you don't end up having to remove the hard drive chassis to install the grommets, as they're already installed and hold what is now the original drive. I removed it anyway, because I wanted to install two new SSD drives, but now if you're just adding one drive, you don't have to. I think you could probably squeeze in a new drive without even removing the power or logic boards.
There are two 6.6 mm T8 screws connected to the antenna (in step 8)- when you try to remove them at first, you can't, because they used to connect to the hard drive that is no longer there. When you remove the antenna, you find Apple has loc-tited two little hex nuts on instead, but these are easily removable. You'll actually end up using these for their original intention (to secure the new drive).
The first thing to deal with is the kit ribbon cable, as you have to get it to connect to the left port now, not the right. It took me a couple tries to get it right- you have to kind of fold it over on itself in a Z near the HD end, and sort of reverse the folds near the logic board end. You can't be too precious about it- they're made to bend.
So you kind of eyeball it, stick it on the HD, and slide the HD in. I used a spacer that came with my hard drive to help support the space between the two drives, although it was more for peace of mind. After that you just put the antenna back in, and you'll see that the two 6.6mm T8 holes will line up with your hard drive perfectly (although the newly installed ribbon cable almost blocks one of them- you can make them both work). I just installed both screws and called it a day. I was using really light SSD drives, so I felt okay only having one side truly supported.
However, it seems on the older design, the original drive had two little bumper screws or something that slotted in to two little circles in the plastic IR/power LED piece (the seemingly unremovable part from the inside of the face of the chassis). With the supplied hardware, there's no real way to re-create this as the standoff screws they supply are too long. Like I said, I felt fine just using the antenna screws.
Basically, all you would need for a "kit" now would be a newly bent cable, and two little bumpers to secure the far side of the new drive. You'd only need the U-shaped logic board tool if you were messing with the original drive. $50 is now seeming pretty steep for what you actually need, although the toolkit they include is pretty awesome.
I powered it up with some trepidation, but everything works fine.
这个答案有帮助吗?
得分 1
添加一条评论
Too bad to hear. I think the only way is to get a refund. Kit supplier refused to agree that Apple make the switch. Some even questioned my model is refurbished.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stephentsao 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 336
