跳转到主内容
戴尔所制造的笔记本电脑。
1946 个问题 查看全部
i'm rebuilding my laptop that driversneed to configure it again
i have a latitude e 6400 screen will change the hard drive and increase you memory. i had windows 7 32 bit, now i want to change to window 7 64 bits, i should do.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
最有帮助的答案
You will need to reinstall Win7 64bit in place of the 32 bit, you cannot upgrade. Here are the drivers for Windows 7, 64 bit: http://www.dell.com/support/drivers/us/e...
Changing the hard drive and adding memory should not require any drivers from Dell. Also, you may want to check the specs to see how much memory that particular model will accept.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
juan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 88
