跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
Water damage. Battery drains quickly and slow to charge. What to do?
My phone got some water in it. Operationally, it works fine however sometimes the volume button doesn't work, it won't stay turned off, and it overheats. Mainly the battery is draining 1% every 2 minutes.
I took it to the Apple Genius Bar and was told chemically the battery tested out fine and that the water damage to the dock may be tripping out the battery (that sounds funny)
My question, should I replace the battery or the dock? Similar questions on here showed mixed responses and outcomes.
Would appreciate some advice. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Jennifer, so far, what have you tried to fix it?
完成的
添加一条评论
5个答案
已选择的解决方案
Volume Button mainly a problem of flex cable . dismantle the Iphone to check the Liquid damage on the logic board. clean it properly. leave it for 3-4 hours after washing the logic board. During that time check all the flex in frame . check for damage. if have damage replace it with new . then put together all the things like before and use it . check problem is there or not . try this first.
这个答案有帮助吗?
得分 1
添加一条评论
Jennifer, besides all the things SIMRAN suggest, I would go about it this way. Disassemble your phone using this guide. Clean every parts with 90%+ isopropyl alcohol. Use this guide to see how to clean it. It was written for a 3G but all the steps apply to your phone as well. Once it is cleaned properly, replace the battery. A water damaged battery " it overheats. Mainly the battery is draining 1% every 2 minutes.", might be the reason for that. Once you have all that accomplished, reassemble and re-evaluate. this is not to say that it will fix it 100% but at least you have a definite starting point. There is of course still the possibility that your logic board has a damaged PMIC or various other SMD components. So make sure that you take a good look at all those when you disassemble your phone. Hope this helps, good luck.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 4S 逻辑板图片
指南
iPhone 4S 逻辑板更换
难度:
困难
1 hour
这个答案有帮助吗?
得分 0
1条评论:
Thanks oldturkey03. Do you think it could be the dock at all? The Apple agent mentioned there was corrosion and that the dock is confusing the battery because it's damaged, making it charge slowly and drain quickly.
完成的
添加一条评论
I have similar problem with a samsung and changing the battery didn't help. So i'm trying to find out what it could be.
这个答案有帮助吗?
得分 0
添加一条评论
put a battry in high sunlight for 4 to 5 hours then ur battry work fine ,,,
这个答案有帮助吗?
得分 0
添加一条评论
Hi I had this problem with an iPhone 5 which got wet in the rain but seemed to continue to work however the battery was draining quickly and sometimes it was not charging or switching on. I opened it up and used a hair dryer on hot to dry the top and to bottom of the phone (not the battery as I heard this was bad for it). Left it for 10 minutes to cool then repeated the process - the case was very hot. Works like a charm now good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jennifer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 56
总计 48,497
