跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3356 个问题 查看全部
Bottom case housing replacement?
Hi,
Is it possible to buy only the bottom piece of housing that holds the dock connector and the speakers? My iPhone 5 fell on it and the aluminum is kind of dented a bit.
Greetings,
Sam Van Damme
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
已选择的解决方案
Hi samvandamm,
I believe you might need to get you a new frame/rear panel.
Dock connector and speaker are built into the housing, which is one unit. See this guide for the iPhone 5 speaker replacement.
In other words, there is no bottom piece that could be replaced. See also this posting iPhone 5 Rear Panel Replaceability.
Steffen
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
samvandamme 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 554
