跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
Black screen with stripes after replacing front panel.
I followed the guide to replacing the front pannel. Once I finished, i realize that the phone was probably turned on. After that, I have tried to hard reset it, but it didn't work. Sometimes the screen goes black with vertical gray stripes, sometimes not. What means that? Could be the fact that the phone was turned on when I was working on it a possible reason?
Many tanks.
Nico
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If the phone was on when you disconnected the battery there is a chance something may have happened...but for it to be doing what you have described is strange. Have you tried re setting the connecting ribbons (with the phone turned off)? If that doesn't work it may just be the screen that may be faulty.
这个答案有帮助吗?
得分 1
2条评论:
I haven't tried to re set the connecting ribbons with the phone turned off. I should try it. Anyway, the screen was the older screen of the phone. Is there a chance to damange it while phone is turned on?
完成的
...and how can i turn of the phone if the touch and the screen doesn't work?
完成的
添加一条评论
It involves a little more work, but you could also try lifting the logic board off from the battery just enough to let the phone reset everything. Then putting the phone back together and turing it on with the display in.
这个答案有帮助吗?
得分 1
7条评论:
I've already done it.
完成的
How did it go?
完成的
Nothing changed.
完成的
Try a new screen... I have a feeling that its a faulty screen.
完成的
Maybe the screen is faulty, but the phone is turned on right now. How can I turn it off?
完成的
显示更多的2条评论
添加一条评论
Check the flex cable.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 428
