跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why won't my power button click?
my iphone lock button randomly stopped working and i have tried replacing it, but i cant get the button to pop up (as if it is constantly stuck down. the cable works as i can push the button with a pen if i use the phone without a lock button. i just dont know why when i put a button in, it will not click
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
if you replace the ribbon cable and you are having the same issue. try loosen the screws a lil bit. this should work
这个答案有帮助吗?
得分 1
1条评论:
Had this on one before and ended up slightly loosening one screw as suggested above.
Had tried unsticking and re-aligning the flex several times but never got it right.
I now have a patly-rebuilt 4S total strip down with a volume+ button that is similarly not playing ball :(
完成的
添加一条评论
添加你的答案
lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,299
