跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
After water spill, screen has gone black - inverter board?
I had some water splash onto the bottom of my MacBook Air. A day later, the screen is extremely dark, but I can just barely make out the desktop. I'm thinking this means the backlight has been fried? Is this something that can be fixed by replacing the inverter board? Any advice would be greatly appreciated.
Additional info: I can plug in an external monitor and get a fine image.
Updated question: Can't find a repair guide for fixing the backlight or replacing the inverter board/cable on the MacBook Air. Anyone know of one? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
"normally" this can be a inverter or a connector issue - but it can also be some power related problem - the only way to find out is to open the MBA - then you will see whats "shorted"/fried
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply! I've opened the machine but can't see any obvious marks indicating what might have fried. Any suggestions of what to look for?
完成的
did you look in the area where the fluid came into the MBA ?
i use a magnifying glass - that kind what whatchmakers use for my logicboard searches - that way you can see the fried solderings better
完成的
添加一条评论
Just wondering if you ever managed to find a solution, I had the exact same thing just happen to me this week. I'm wondering if there is an LCD inverter separate from the mainboard or LCD assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mister790 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,825
