跳转到主内容
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 个问题 查看全部
Wifi/Bluetooth unable to turn on, possible broadcom chip damage?
Hi!
A few weeks ago I dropped my Verizon Note 2 SCH-i605 and smashed the screen, requiring replacement of the display. I brought it to a local repair shop, and received it yesterday.
The screen works, but now the wifi/bluetooth functions will not turn on when I press them. They will both slide to "on," and after about six seconds will slide to "off." I don't get any message about activity or errors, they just slide to "off."
I hypothesize that the broadcom BCM4334 wifi/bluetooth chip has been damaged in some way (or removed), so it won't work, period. I opened up the phone and took two pics of the motherboard's sides.
My questions: What does the BCM4334 chip look like on this phone? Where is it supposed to be, so I can determine if it is still there and in one piece?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
最有帮助的答案
Hello Friend.....Myself Dipesh Patel.
The same problem was happened with my phone although my phone's model no:. is GT-N7000 but the IC for WIFI/BLUETOOTH was at the same place and of broadcom......and it is placed just upside of the battery connector,remove the silver cover from it you will see the IC......... Please If you fine the IC reply me on this number.+917405436155
这个答案有帮助吗?
得分 2
添加一条评论
Miner has the same problem - got driven over, saved by the case for the most part.
Check out this site I found, from Samsung - wifi Bluetooth chip is 9-5. Hope that is a bit helpful.
http://global.samsungtomorrow.com/?p=290...
这个答案有帮助吗?
得分 1
1条评论:
Same issue here.
little Tap/hit on a back solve the problem untill it happens again. I think this is the issue with phone hardware..
完成的
添加一条评论
添加你的答案
Sen Menendez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 37
总计 32,177
