跳转到主内容
Repair information for the first generation Apple iPad available in Wi-Fi and 3G versions with 16, 32, or 64 GB of storage. Released on April 3rd, 2010. Model numbers: A1219 and A1337.
266 个问题 查看全部
ipad 1st gen "not charging" problem, any fix?
hi there, i have an ipad 1st gen,, when i put charger in the socket it comes up with "not charging" i have tried 2 chargers with no luck the chargers i tried are the original ipad 10w charger, i have searched alot around, and i can see many have this problem, but do anyone know how to fix it??
regards
tonnie
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
The older large iPad chargers have known problem I had similar problem With three other charges I ignore the charges unused the simple charger underwear the problem went away I suspect the knockdown transformer inside these were overeating and failing but I don’t know yet. I’m trying to find the schematics of one of these charges. The other problem to be aware of is if you buy these charges on eBay and they haven’t been tested the person is likely to sell you a faulty transformer believing it to be okay so beware of this because you still got the same problem
完成的
添加一条评论
4个答案
已选择的解决方案
tonnie, it is entirely possible that it does not charge because of a faulty battery. I suggest you start with that. Pick your iPad from the guide list and pick the one for your battery replacement. After that, reevaluate. At least that way you have a know good starting point for any further trouble shooting, should it be necessary. the error can also originate in the dock connector, the charging circuit, bad charging coil, bad charging diode or bad power management IC, but unless you have a known good point, it will be more of a guess than anything else. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
thx, i replace battery before i try other solutions..
regards
tonnie
完成的
添加一条评论
最有帮助的答案
Ipad 1 does not charge with its charger. But any apple mac book can charge the Pad 1 through the USB connection. Somehow Apple had dropped support for this charger and want us to use a laptop or imac to charge the ipad 1. The logic of this operation is to encourage you to use iTune and sync.
这个答案有帮助吗?
得分 4
添加一条评论
I think faulty battery, It will charge if plugged into the PC/MAC however it takes a full day or or two to fully charge even though it still says "not charging". Charging sign comes on or off, so I do not rely on that. Mostly battery issue to me. Your average rechargeable batteries are only going to last 3-5 years anyhow.
这个答案有帮助吗?
得分 2
添加一条评论
I also had this problem and i fixed the issue all i did was take a clean tooth brush and some 70% rubbing alcohol and cleaned the charging port on the iPad as well as the USB Cable both ends of the usb cable because these three connecting points tend to get dirty over time so now it is charging hope this helps anyone with this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tonnie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 65
总计 37,889
