The power button button cannot be pressed
The power button button cannot be pressed, is need to replace the entire line, or just need to replace promptly? Hope to have the detailed change the power button row line tutorial
Vicky, here is the guide and you can get the part from here. It may of course be possible that you require a new cable, for that follow this guide and a new part from here. Hope this helps, good luck.
指南
难度:
困难
15 - 30 minutes
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
I replaced the power button but that doesn't fix the problem. It is still stuck in the depressed position. Does the power cable include the piece that the power button depresses which makes it otherwise function?
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 609
