USB-port replacement due to bend pins.
Hello there!
I got a question regarding the USB-port connector. Do you guys know what sort Apple is using for their products?
Can you replace it with a regular USB Type A connector 4P?
As this port is built into the logic board, you might want to try to straighten then or have a tech do it.
这个答案有帮助吗?
I have tried that but its too far in, I can't seem to get a hold on the bend pin. Its pressed against the back of the connector. And if I get a hold on it, don't you think it will snap since its been bent once already?
Picture of it: http://img199.imageshack.us/img199/9486/...
@Frederik, looking at the image, I would think right now you do not have much to lose. I would use a few straight pins and tweezers and give it a try.
Looking at your picture, I would use a dental pick (the shepherds crook type), see these: Probe and Pick Set
I found a old tweezer but it was too big so I had to modify it, after that I tried grabing it and after awhile I got it! I straighted it out and pulled it to place. It seems to work!
http://img547.imageshack.us/img547/4076/...
The tweezer didn't leave beautiful marks but who cares, it works! I haven't had 2 usb-ports working for over a year!
Thanks for the help :)
Great job:-) Now all you have left is to accept mayer's answer as the one that helped you the most :-) that way anybody having the same issues will know what might work. Best of luck to you
Tried fixing mine with a paper-clip. I thought it got it into place, but after testing it twice, gingerly with a USB cord it broke :(
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,397
