Heat Sensor Problem 4SNS...Th0H
For some time my MacBook Pro has been running slow and the fan runs constantly. The closest Apple store is 3 hours away and I haven't had the ability to surrender my laptop for more than a day so I've just been living with it.
I ran the Apple Hardware Test today and it gave me the following code:
4SNS/1/40000000: Th0H - 78.250
As best I can figure, this points to a heat sensor but I can't tell if its something I could fix on my own or if I'm at the mercy of the unavailable and expensive Apple Store. The only repair guys within a reasonable distance have a horrible reputation so I've done everything myself up til now. I think this may be above me, however. Is it?
Help? Anyone? TIA!
2条评论
try to download "iStat" and see what it tells you on the heatsink side.
由 oldturkey03 完成的
Thank you, oldturkey03. I downloaded iState (very cool, thank you!) and captured two readings several minutes apart, after resetting PRAM and SMC. As follows:
HD 42/42
CPU 94/70
Airport Card 51/48
Enclosure Base 26/26
GPU Diode 91/84
GPU Heatsink 71/66
Heatsink A 69/65
Heatsink B 47/46
Right Fan 4292/4360
Left Fan 4292/4364
I have no idea what these numbers mean, though! Any help interpreting them would be super appreciated! TIA!
由 Tracy 完成的
