跳转到主内容
Does this display certainly need replacement LCD?
There was a pretty ugly coffee spill... The only remaining symptom is the display.
No problem seeing the complete screen in screen sharing but I haven't hooked up an external display for a test yet.
One tech told me it was the display (not the video) but I'd like to confirm this if possible.
NOTE: Photo is upside down! Sorry I couldn't get to go in right side up.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Glossy LCD? - I'm assuming you've replaced the lcd before?
but as far as it goes, it looks like the LCD needs replacement. Could be the video but unlikely. You'd have to connect to external to test.
这个答案有帮助吗?
得分 2
2条评论:
The sure-fire quick test is connect to an external. . . no problems it's in the internal display chain... problems it's the VGU (VGC).. FIW you're not "seeing" the screen in screen sharing, just the data that would be displayed.
完成的
Thanks! I will check with external display before ordering a replacement.
完成的
添加一条评论
I'm guessing that it's the video card since the coffee didn't spill up. It might be the display, but I hope you had someone dismantle the entire computer and scrub all the coffee gunk off it so it doesn't develop corrosion over the next few weeks. Just my opinion from experience, but the display isn't usually the victim from spills onto the keyboard (if that is what happened).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Richard Talcott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 170
