跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
on board wifi contact is broken! any way to find alternative?
Hello!
my friend iphone 4 got a massive damage... i replaced almost every part of the phone(everything works perfect!!) but there is one problem - the wifi contact point is broken on the board so there is no place for the antenna to touch... here is a picture so you can understand better what im talking about:
http://i.imgur.com/cYmyFcP.jpg?1
is there any way i can connect the wifi antenna to an alternative point on the board? soldering is not an issue...
thanks a lot!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
this should help you a lot
http://img20.imageshack.us/img20/3396/ip...
You will probably need to solder a wire from the metal plate to the line
这个答案有帮助吗?
得分 2
1条评论:
Excellent post & diagram. Bookmarked for future reference, if needed. Kudos
完成的
添加一条评论
添加你的答案
Yogev Ifergan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 484
