跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Rear Camera Not Working
Hi!
I've a Iphone 4s that the rear camera wont open the shutter after replacing the screen.
Also the flash doesnt work either (have tried with the torch app), I've tried to replace it with another one but that didnt solve it.
The front camera works.
I've read this Guide: iPhone Troubleshooting Guide 101
But it applies to Iphone 4 and the logicboards aint the same.
I've also tried to reset it etc, no luck.
So is there anybody who is sitting on a solution for this?
//BR
Patrik
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
If your camera is correctly plugged back on the motherboard try this:
There's a golden connector/bracket you need to put back in place between the camera & top of the iPhone. Is it there?
Check what it looks like on Google 'iPhone 4s gold camera bracket'
这个答案有帮助吗?
得分 0
添加一条评论
hi, i have the same problem, and i have that golden bracket that u mentioned in place, maybe its the motherboard that's broken?
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, my lock button was replaced, tried opening the camera app, and left with the shutter screen, camera has been replaced still no joy this is on a iPhone 4S, been told it could be the main board, any other solutions?
这个答案有帮助吗?
得分 0
添加一条评论
I also changed the lock button on the phone and now I'm having the same problem with the camera. Has anyone come across a solution yet?
这个答案有帮助吗?
得分 0
添加一条评论
just bring to the apple shop and they will tell you that the wire was disconnected so your ask them to fix it, wait for 45 minutes. I my camera is working quite good now.
TQ .
Benedict King Reutens
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,976
