跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
White screen, after replacing glass?
So i tried to repair my glass/digitizer and everything was fine until i saw the screen itself was defective since the replacement glass was not responding.
Me wanting to put back the old glass (it only had 1 crack) accidently pulled too hard on the suctioncup on the screen and ripped out the whole screen from all it's connectors on the motherboard. Luckily nothing was damaged from what i can see on the 1/2/3 wires, but now connector 3 has become loose in the sense that i can put it's wire in it and close it with the lock but i still comes out relatively easy, so i don't know if thats it.
After i switched those screens and connected everything i've gotten a white screen. (The sound still works though everything does actually except the screen itself)
I've read that i had to try and push on connector 1, straighten out the wires and clean them, but none of those things worked out.
I'm thinking it might be one of the connectors or the lcd itself might be the problem.
I hope you guys can help me with this though.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you had the power disconnected or rebooted the device since the white screen started showing? Sometimes it just needs a restart to recalibrate the LCD.
If rebooting the phone(by holding home+power for 10sec) doesn't work, then the LCD is probably damaged.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 478
