跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2170 个问题 查看全部
问题已关闭
iPhone 4s dropped wont turn on
hi, i hope u can help
i have a iphone 4s,GSM, the screen broke, it broke so much, that the logicboard is a little bend,ant the middle frame has a slight bend also.. a laptop was dropped down on the phone, the phone is all dead, it wont turn on, even with charge cable, i tryed hard reset with no result,cant connect to itunes either,screen replaced, battery replaced, nothing works, what can be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
i have pictures of the damage, if that can help solve the problem.
完成的
添加一条评论
1个回答
已选择的解决方案
Sadly, it sounds like a faulty logic board if you say "it's bent".
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 433
