跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
4162 个问题 查看全部
My battery does not work any more
I have a MacBook, three or four months ago it fall water over it and since, the MacBook does not recognize its battery any more so I have to use it only with electric power. I took it over service and they told me that some "electronic component" is not working. Where can I get the part that alows the computer to recognize the battery again? (I don't know the name of the component)
Thank you very much for the information you can give me.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
评论:
my Battery is not working as well i need help plz i don't own the gopro i have so i need some one to fix the Battery
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
Hi! It sounds like you may have a faulty battery connector. I would suggest identifying your MacBook via our ID Your Mac page and then use the appropriate guide to replace the battery connector. If you have a MacBook Core 2 Duo, use this guide. If you have a MacBook Core Duo, then use this guide. Hopefully this helps out.
MacBook Core Duo Battery Connector张图片
指南
MacBook Core Duo Battery Connector Replacement
难度:
中等
MacBook Core 2 Duo Battery Connector张图片
指南
MacBook Core 2 Duo Battery Connector Replacement
难度:
中等
这个答案有帮助吗?
按维修分数 3
评论:
Since the unit has had water on/in it I wonder if the battery could of shorted out and no longer be functional. Perhaps the OP could try a different battery and see if that works. Ralph
I've very rarely seen the connectors fail. I would do as rj713 recommended. But the answer by Walter is the kind of documentation I like to see and almost got an upvote form me. Maybe a bit of editing would make it better.
添加一条评论
添加你的答案
nataliagonzalezortiz 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,063
