跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
204 个问题 查看全部
Mac mini not powering on
Hi
I've got a mac mini mid 2011 from ebay and it doesn't power on. I'm testing the power supply and following the guide, I should have 12V checking the two outer pins. When the power cable is connected I got that voltage but as the time pass, the voltage decrease going to 0V.
Is this behaviour normal ? or is the power supply defective ?
for instance, the power supply installed is an oem from delta electronics 614-0503, not a 661-6085.
Has anybody have experience with those power supllies ?
thanks
Daniele
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The power supply should be Part Number: 661-6085. But the 614-0503 is also listed for this machine: http://www.techrepublic.com/photos/crack...
It's very common to have more than one parts supplier. I think either one will work for your replacement.
这个答案有帮助吗?
得分 3
1条评论:
thank you for the answer.
But Is power supply's behaviour normal ? or is it defective ?
If tried even to put a resistor in order to have a load on the output and the voltage decreased faster.
完成的
添加一条评论
The behavior indicates a failed power supply; the supplied voltage must not sag too much. Probably a bad capacitor or something wrong with the feedback circuit in the PS; Just replace it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniele Acquadro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,076
