Lock Button not working after Digitizer Replacement
So i have changed the digitizer and soldered the connectors for the home button and digitizer.
Now when i press the lock button nothing happens unless i hold it and eventually it gives the option to turn off.
I noticed this question has been asked but at this moment there is no solution in that question:)
Many Thanks
I am having this exact same issue with an iPad 2. Tomorrow morning I am going to try a new cable to see if that fixes it. I will let you know.
由 Caleb Baker 完成的
Hello, I have the same problem and wanted to ask if you figured out how to fix the problem after replacing the digitizer and home button after being soldered together. Thanks.
由 Ivan 完成的
