跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
iPhone 4S Serial Number Question
So, I had my iphone color changed from white to blue... But dropped it and had the person place my original white screen back on so I can take it to Apple since my earpiece and speaker don't work well since dropping it... But for some reason they are telling me that the serial number in Settings>>>General>>>About>>>Serial Number and the serial number inside of the iphone don't match. Not sure what the guy did or what piece of mine he might of switched whether on purpose or by mistake but how can I know where the other serial number is located? Need help please...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
rayrod354, it is on your sim card tray, see attached image from here. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
1条评论:
Aha.... I knew about the sim card tray but I think that's what happened... The one that is on the flex cable cover is that one that must of been confused and put wrongly on my phone...
完成的
添加一条评论
iPhone 4S Serial Number is also printed on the small Flex Cable Cover (held down by two screws) of the Dock Assembly Flex Cable Connector to the Logic Board.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
@Brad means this
这个答案有帮助吗?
得分 1
添加一条评论
Matthias is absolutely right about the information. Now your phone warranty is avoided due to Unauthorised Modification. if you have same matching serial no . you can try to request them if they understand they can replace the phone. otherwise change the phone . Sell it and buy the new one .
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,811
