跳转到主内容
Compact device for setting up a home wireless network
16 个问题 查看全部
What Supply Voltages and Currents Does It Need?
I want to run an AirPort Express off a battery power supply. The cells I will use have a nominal voltage of 3.2V.
Could I run this with a 5.1V 1A source AND a source with virtually unlimited current and a voltage that fluctuates between 3.1V and 3.4V?
(By the way, those were two separate supplies mentioned, separated by AND. Not sure if that was obvious. Thanks to iFixit's power supply replacement instructions, I know that the AirPort Express requires two separate voltages.)
Rather than answering the above question, you could tell me exactly what two voltages it needs and the maximum currents it will draw at each. That might be easier :)
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
This question was migrated from http://meta.ifixit.com/Answers.
What amperage does the airport base station require
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
1个答案
已选择的解决方案
It runs at 3.3 volts. The guide is excellent on this, you may want to review it: AirPort Express A1264
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
iEvan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 9
总计 1,615
