跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2517 个问题 查看全部
iPhone 5 home button not aligned after replacement?
Dear all, I have myself replaced the home button of my iPhone 5, the button itself and the ribbon cable.
Since then, sometimes the home button is slightly tilted to the left and sometimes to the right, which is a little bit annoying.
When I carefully disassembly the home button + the rubber gasket I noticed there was between the rubber gasket and the display assembly a very thin layer of adhesive.
Could be this adhesive the responsible for keeping the home button aligned or there is something I am missing?
If so, where could I get this adhesive?
Any help will be welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If Apple did the same thing they did with the 4 and the 4s then yes. Unfortunately that very thin layer of adhesive is responsible for holding the home button in place...
I'm not sure where you would be able to get the adhesive but when I did the repair on my 4s I just placed a cut strip of electrical tape over the back of the home button and it did the trick! Haven't had a problem since!
EDIT: Looking back at the teardown of the iPhone 5 it seems they introduced a support bracket that I assume was supposed to help with this problem (iPhone5 拆解)... I would check to make sure that bracket is fully tightened down, otherwise I guess you could try the tape method. Either way good luck!
这个答案有帮助吗?
得分 1
1条评论:
Yes, I also thought the metal bracket was to help with this problem. Unfortunately the bracket itself, without the unknown adhesive, is not enough.
Still I would love to know which kind of adhesive apples uses to glue parts that should be in place without glue. I bet this will be slightly modified in the next iPhone model.
If impossible to know, I will try you suggestion, of placing a cut strip of electrical tape over the back of the home button.
Thanks!!!
完成的
添加一条评论
I have used a piece of two sided tape it worked fine. Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
IgoKW 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,351
