跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2962 个问题 查看全部
Screen colors all messed up after dropping it
I was unfortunetaly very clumsy today and dropped my Iphone 4S. Even though it had a thick case on the top right corner got a scratch and now the screen shows messed up colors. At first it was all white and I could only see the date at the top. Now I can kinda use it but it's hard to see well and a part of the screen doesn't show at the right bottom. The screen isn't shattered so I'm guessing it's a more internal problem, right? I don't know what to do as it's a phone I bought at Apple store in Canada and I now live in Thailand where there is no official Apple store. I'm still under a regular 1 year warranty. Can somebody advise me what to do? I'm very worried and don't have any friends with IT knowledge here...
Thanks,
Isabel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
评论:
Karen Turner
完成的
Someone please answer this question. I have the same problem.
完成的
添加一条评论
4个回答
已选择的解决方案
You could try to follow THIS guide to Step 16 and check if all the connectors are connected.
But I think most probably the LCD is broken and you need to replace it.
这个答案有帮助吗?
得分 2
评论:
the same thing happened to me. someone bumped into me and my phone fell out of my pocket. you have to go to apple to get it repaired. there going to take off your glass screen and they will replace you bottom screen with another so you don't see the lines on your phone (whatever color they are).
完成的
how much would this repair cost if I were to go to apple for this same type of damage?
完成的
my iPhone's screen was cracked a little but then it accidentally fell out of my pocket and the button to turn on the iPhone came off,I put it back on and turned it on and my screen was all mest up,is there anyway I can fix it besides going to apple,can I buy a screen and just replace it,are they expensive p?
完成的
My phone dropped on the floor and my screen is like a totally different color
完成的
idk what type of iphone I have but magenta lines EVERYWHERE my iPhone also stoped working :( thank you I also can't use it NOTHING will work
完成的
添加一条评论
Same thing happened to my 4... What happened is that wherever it broke, the 'injury' is scrambling the screen's color information. If I lock and unlock my phone, sometimes it shows completely scrambled except for the top status bar, and sometimes only the color is scrambled...
Anyway repair is really the only way to fix it, unless you come up with a workaround. I've enabled the settings that blind people use, so my phone reads to me everything I click, but I don't really need it as sometimes my phone does show up everything just in the wrong color. I know this was posted quite a while ago.
这个答案有帮助吗?
得分 2
评论:
Help I dropped my iPhone and the top left corner of the screen the screen colour is black and all sorts of colours HELP‼️‼️‼️‼️
完成的
添加一条评论
This really helped me after I dropped my phone. There were hues of colours on the screen. I went to settings > general> Accessibility > display Accomodation > and then changed the grey setting to ON and then switched it off again. It done the trick and the screen more or less has gone back to normal just a very slight colour change still exists in the corner
这个答案有帮助吗?
得分 0
添加一条评论
I just dropped my IPhone 6s and the colours are all messed up in the bottom, like a virus my phone was already smashed a little but now it’s just unusable in the bottom right of the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isabel 将永远感激不已
浏览统计数据:
过去的24小时: 18
过去的7天: 133
过去的30天: 616
总计 123,624
