When removing the battery I pierced the foil with the spudger.
Whilst removing the battery I pierced the foil with the spudger, can I still use the battery and can I repair this with anything.
THANKS
Mike, I most certainly would not. If the battery's outer case is punctured, the lithium inside is highly volatile and can react violently with water, which includes humidity in the air. I would discard it properly and get a new battery
这个答案有帮助吗?
Thanks for the reply, I will dispose of this one then. Do you know where I could source a replacement.
Regards, Mike
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,855
