跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
914 个问题 查看全部
问题已关闭
Replace the screen and iPod don't react anymore
Before tear off the screen the ipod works, but the glass was broken.
I did the same procedure as many times and by replacing the new screen the iPod don't react anymore. Also not on the pc or notebook.
First I thought the battery, so I replaced that also but no response and result.
What can it be, the logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Put the cracked screen back in and see if it works maybe the new one is a dead one
这个答案有帮助吗?
得分 0
1条评论:
I already replace the cracked screen and still the same problem. Doesn't work and Itunes or PC don't reagornize the iPod. I also tried new screen, but still not working. What can it be?
完成的
添加一条评论
I concur with the above answer.. Too many times, I get bad digitizers, right out of the package. I have even had the digitizers and the connectors come out of the bag, completely separated and obviously never working.. Hint: When taking apart the iphones, ipads or ipods, always try to salvage the digitizer, that is do not break it in case you get a bad one. Of course, having another one or two new digi's around is nice and makes checking things a lot easier, for someone doing a one-time fix, buying extras is out of the question. Plus, a test box to test digitizers is over 1300.00, and not many shops even buy them.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 226
