跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 个问题 查看全部
问题已关闭
rain leaking from the ceiling to my phone while charging
was charged and then rain leak from the ceiling, after a while it having problem while charging giving message that battery is disconnected, it went on until it cannot charge anymore, battery checked its working, technician said the board is rust, how can I justify the technician report and where can i get new board....
Update
Samsung Galaxy II
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Jona, first off, what model Samsung phone is it?
完成的
Samsung Galaxy II
完成的
thank you, I will try to do it, and then will update
完成的
添加一条评论
1个答案
已选择的解决方案
Jona, the first thing I would do is to disassemble the phone. Take a look at this teardown to see what needs to be done. It is not a complete guide, but does help to remove your logic board. Once you removed it, I strongly suggest that you clean it, use this guide to see how to clean it. the guide was written for a iPhone 3G but all the points apply to your phone as well. Make sure that you take a very close look at every connector and see where you find corrosion. You may have to repeat this a couple of times. Once it is properly cleaned replace the battery reassemble and re-evaluate. Hope this helps, good luck.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
Samsung Galaxy S II图片
指南
Samsung Galaxy S II Teardown
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 320
