跳转到主内容
苹果Magic Mouse鼠标是由苹果公司制造和销售的多点触控鼠标。它于2009年10月20日首次公布和销售。
52 个问题 查看全部
Mouse works intermittently, loose connection? Can it be fixed?
Follow a drop on a hardwood floor the mouse works intermittently. Will work, if connection established, for a while as long as not picked up and moved. On/off light either works, doesn't work, or flickers when trying to reconnect. Change of batteries does not change situation. Possibly a connection loosened by being dropped to floor. Can it be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
mtuck205, yes, based on the symptoms you describe, it is possible and very likely that you have some loose component. Unless you open it up, use this teardown for some direction, we will never know.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mtuck205 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 3,475
