跳转到主内容
Model M7572 / 400 or 500 MHz G3 processor
45 个问题 查看全部
pismo not getting power when power cord is attached.
My pismo was working perfect one day and the next would not power on. If I attach the power, it does not show the battery receiving any power from it thus not turning on. I have tried other power adapters that are proven to be good power sources but with no luck. Any ideas on where the problem may be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I had a Pismo conk out on me after having been in storage for a while. In the end, I opened up the machine and replaced the little battery on the logic board and it started back up again. But there are folks online who are saying that you might not even have to replace that battery -- just remove it, restart the computer, then plug the battery back in to recharge it. Here's that thread with all the details: http://forums.macrumors.com/archive/inde...
Not sure if this is your problem, since it sounds like your machine hasn't been in storage. But it might be worth a try!
这个答案有帮助吗?
得分 1
2条评论:
I noticed same thing after my Pismo sat idle for a long time, it wouldn't boot at all. simply unplugging the little battery on the logic board allowed it to boot again.
完成的
Thanks for all the info. I have not had any luck with the pismo getting power but I will check the DC board, Thanks so much.
完成的
添加一条评论
最有帮助的答案
It sounds like your DC-in board has failed. Unfortunately, iFixit is currently out of stock on this item, but here is the link to the page anyways. You can find the apple Part # and maybe search google to find another site that might have one.
[关联产品丢失或禁用: IF106-003]
这个答案有帮助吗?
得分 2
1条评论:
Tyler - Would you take the step and purchase the DC Sound card or would you suggest getting it checked out first. How strongly do you feel that it is the problem? Thanks for your time - Gary
完成的
添加一条评论
I had a similar sounding problem with my Pismo, except that the power was intermittent - if I wiggled the power connector I could get it to work. I removed the DC board according to the ifixit repair guide and resoldered the connection between the board and the connector - everything was fine again. I think the years of plugging/unplugging the adapter stressed the connection on the board and/or there was a weak solder joint - it does seem to be a bit of a stress point as the plug fits very tightly.
can you get power at all if you gently wiggle the adapter connector when plugged in? if so try resoldering the connector. if not, then as mentioned above it's likely a bad DC board.
这个答案有帮助吗?
得分 0
2条评论:
I have attempted to wiggle it to see if I can get power but with no luck.
完成的
ok so if it's not intermittent then maybe good chance it's the DC board itself. since ifixit is out of stock, I know for sure there are other sites you can find on google selling this board and other ... PB parts ... I've seen the DC board listed elsewhere (but it's cheaper here on ifixit!) Not sure what else you can try short of replacing the board...
完成的
添加一条评论
Definitely works unplugging the pram battery!
Easy to try and don't cost anything!
Give it a try first :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
montanaman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,389
