跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2517 个问题 查看全部
Front camera shutter won't open after teardown
I did a complete teardown of the iPhone 5 and then when I put it back together the front camera is stuck in the shutter just like the iPhone 4 used todo. Is it something I did, I know on the iPhone 4 when unplugging the cables it was possible to break off one of the connections bridges on the logic board. Is this what happened? Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
It is the same connector that broke off on all the iPhone 4's. Just be careful pulling up the cables for the display and you shouldn't ever have a problem!
完成的
I have the same issue, what to do?
Tried replacing front facing camera - no effect, connectors looks okay.
完成的
Thank you very much for your kind information Zack, looking forward to see the pictures!
完成的
please post pictures of this soon, as I have exactly the same issue with my Iphone 5, and its just sitting there not being used, and many thanks for everyones contributions, your all legends!
完成的
Zack, Please post the pictures of this repair. I can't find them anywhere.
完成的
显示更多的2条评论
添加一条评论
4个答案
已选择的解决方案
It is one of the very small bridge connectors that are all over the logic board. It was one to the right side of all the connectors. It must of got broken off when you were popping the connectors out. All you need to do it to get some liquid solder and dab just a little onto that place where the connector has been broken to bridge them back together. I will be taking my phone apart in the next couple of days and I will take a picture of exactly where i soldered and show you where the connector on the board is. They are very very tiny and hard to find. I had to use to magnify glasses to find it.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
you will be able to exactly where the resistor is so I can solder? him back together a photo.
gr davey
这个答案有帮助吗?
得分 0
添加一条评论
Hi.
I have exactly the same problem as described here. I really would like to know exactly where this broken connector is so I can repair it with a circuit writer. Zack Seltzer could you possibly upload a picture as you seem to know which one it is that breaks?
Thanks in advance.
这个答案有帮助吗?
得分 0
添加一条评论
I've just had same problem, tried to solder it again, but jeeeze it's to small even for my thinnest tip..
So guess i gone have to try the "draw a new line" :-)
It's not possible to upload pictrues here :-)
If you look at picture in link you will see straight right at the bottom of the right connector thers a missing tiny resistor
Pic of missing resistor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zack Seltzer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,761
