跳转到主内容
数百个光盘驱动器的维修指南。
30 个问题 查看全部
Is it possible to replace a laptop dvd drive lens?
I want to upgrade my laptop's dvd drive to a blu-ray one but they don't sell blu-ray drives for my laptop model so as an alternative I want to open up my dvd drive and remove the lens and if possible replace it with a blu-ray one. Is that possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
Sorry to say this is not possible.
You have very different technologies between the older CD/DVD Vs the BluRay. Between the lasers wave length being different you also have vastly different encoding.
If you could find a drive that would fit you still need to have the software to drive it (Apple doesn't offer it)
这个答案有帮助吗?
得分 2
1条评论:
As the others state you'll need to use an external unit which offers the needed drivers (Mac OS-X)
完成的
添加一条评论
Hi, this might not be the best idea as bluray operates at a different wavelengt and as so will not be compatible with the rest of the control electronics in your existing dvd drive. What kind of computer do you have? Even a laptop should have fairly standard measurements for the bay that optic drives sit in.
这个答案有帮助吗?
得分 0
添加一条评论
get a blu-ray rom, and then go out and buy a corresponding external case, that hooks up to your computer via usb... viola!! you got a blu-ray that works with your computer...
这个答案有帮助吗?
得分 0
1条评论:
No ROM to replace, or a place to even add one. Even on a Windows system you don't need to replace the BIOS ROM to add support of a BluRay unit, you need software drivers just like Mac systems.
完成的
添加一条评论
The Lens is not an interchangeable part between blurry and Std DVD.
If you want Blu ray accessibility and assuming your referring to a Windows machine. The best option is to buy an external blu ray drive. They are designed specifically for external use and have the drivers for the OS, they also are reasonably inexpensive compared to a few years ago. If you are using an Apple or Linux you will need to check the drive manufacturer to ensure they support your OS with corresponding drivers before you buy.
这个答案有帮助吗?
得分 0
添加一条评论
It's not possible. Both technologies are different.
这个答案有帮助吗?
得分 0
添加一条评论
Is there any daughter board that can be added for upgrade?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gonzalo Rubio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 13
总计 5,456
