跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
Is there a difference in the glass between 21.5 models?
Hi,
Is there a difference between the glass parts across
the iMac 21.5" models?
For example, will part number 922-9343, iMac 21.5 Mid2010 work on the Older iMac Late2010 & vice verse?
Thanks a lot!
Eli.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
meerson, specifically for the 922-9343 I get this compatibility:"
iMac 21.5" 2.5GHz Core i5 (A1311) - Mid 2011 MC309LL/A
iMac 21.5" 2.7GHz Core i5 (A1311) - Mid 2011 MC812LL/A
iMac 21.5" 2.8GHz Core i7 (A1311) - Mid 2011 MC812LL/A
iMac 21.5" 3.06GHz Core 2 Duo (A1311) - Late 2009 MB950LL/A
MC413LL/A
iMac 21.5" 3.06GHz Core i3 (A1311) - Mid 2010 MC508LL/A
iMac 21.5" 3.1GHz Core i3 (A1311) - Mid 2011 MC978LL/A
iMac 21.5" 3.2GHz Core i3 (A1311) - Mid 2010 MC509LL/A
iMac 21.5" 3.33GHz Core 2 Duo (A1311) - Late 2009 MB950LL/A
iMac 21.5" 3.6GHz Core i5 (A1311) - Mid 2010 MC508LL/A
from here. If you need anything more specific, let us know which part you have and where you would like to install it to:-). Hope this helps, good luck.
这个答案有帮助吗?
得分 2
5条评论:
Yes I'm doing the 2009 to 2010 upgrade on the 21.5 but I would like to keep my 2009 screen.Will my screen work? Only thing I see is that I will need the 2010 video cable, because board end connector is different on the 2010 board.
Regards!!!
完成的
fernjava1101 we would need the numbers for the panels. There are multiple variances for either year. Once you have the panel numbers, let us know so we can check compatability
完成的
Ok, will do so tonight. Sorry for taking so long, I had placed my comment but honestly I didnt save link nor checked my profile to see if someone had chimed in on my question. Thx!!
完成的
Ok here are some of the numbers I could get from behind the screen.
Upper left corner: LM215WF3​ (SL)(A1)​
That is followed below by:​ RoHS Verified​ Factory ID: LGDGZ​
Another number below middle top barcode:​ *I1A190MC88NWA*​
And below center middle barcode:​ 21505F1618860 673A LIGHT GUIDE: >PMMA<​
Hope this helps.
完成的
BTW mine right now is this one:
MC413LL/A
But Im upgrading logic board to a mid 20010 i3 3.06 and video board connector is different from 2009.
完成的
添加一条评论
添加你的答案
meerson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,395
