跳转到主内容
修复你的物品
维修的权力
商店
My internal hard disk is 0 byte and a flashing question mark
I have been striving to bring my laptop to life, however, I am seeing a flashing question mark on my MacbookPro screen.
Scenario was like : My Mac got frozen for almost half hour and I shut it down by pressing power button.
I tried disk utility and it is just showing me Media and it is 0 byte.
I ran DiskWarrior and it gave following error: An unexpected error occurred while communicating with this hard drives built in S.M.A.R.T. diagnostics, error -536870210, 28260C-
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
2个回答
已选择的解决方案
Your internal hard drive has definitely failed - try booting the computer from DVD after disconnecting the hard drive cable from the logic board.
Do you have the original restore discs for this computer? It requires 10.6.3 minimum, and a Snow Leopard retail DVD would not necessarily boot the computer. There are two revisions of the Snow Leopard DVD - 10.6.0 and 10.6.3. If you have access to another Mac, try creating a Lion or Mountain Lion DVD to test with.
Sleep mode would not cause a hard drive failure, as the drive heads are parked just as if the computer was powered off. A drop or strike, however, could be the culprit.
If you have AppleCare on this computer, I recommend taking it to an Apple Store or Authorized service provide and let them deal with it for you for free...
这个答案有帮助吗?
得分 2
添加一条评论
did you messed up with the drive recent? the '?' symbol indicates that Mac is unable to locate system software to load the OS. Before your Mac froze up did you noticed any unusual drive behavior like some clicking sound?? Disk Warrior is a great tool but tool will not overcome any physical damage caused on the hard drive components. They can cure the logical ones. Would suggest you to try simple steps to cure th issue: http://support.apple.com/kb/TS1440?viewl...
Otherwise you might need a technical expertise.
这个答案有帮助吗?
得分 0
评论:
I tried above link also. My Mac Retail DVD also doesn't boot up and it freezes at Apple Loading screen.
完成的
But I also used to travel keeping Mac in sleep mode. I think this could be the culprit.
完成的
添加一条评论
添加你的答案
Bharat Patil 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 27
总计 3,200
