跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Back camera doesn't work after screen replacement
I replaced the screen of my iPhone 4S. I've done many before, and I'm good at it, I would like to think.
However, when I tried to go onto the camera it just loads the shutter image and wont go any further. The controls at the bottom flash a few times, and some times it will go back to the apple logo and then onto the lock screen. (Not like a reboot, it only takes about 8 seconds)
I ordered a new camera and replaced it, still the same. I've even swapped it for a one I know works and still the same.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I have seen this once and fixed it by restoring the phone several times, that's all I have to offer and hope you get it fixed, good luck, If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
2条评论:
Can you expand? How can a hardware issue be repaired by a software method?
完成的
The way I read your question it sounds like you have ruled out hardware, and your symptoms are the same as the one that I fixed with the restore, unless I'm reading your question wrong,,,, when I was stumped by this I called Apple support and they are who told me to restore, and it did finally work after numerous restores,
完成的
添加一条评论
i have the same problem, I've had it for a couple of months now, never found any solution to this. I think it's a motherboard problem, where you connect the camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamie Simpson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,401
