跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
31 个问题 查看全部
does not come on
my old atari does not coime on whern conected to tv . is there a fuse or something is there a wireing guide, if i take i t apart what elect checks can I do. It set in the garage for several years, I thought it would be fun to plsy with my great grand son .I have power to the unit from the power supply unit ,the tv works fine. connections seem tight are there any units still for sale ? it was a lot of fun to play it years ago . I tryed several different games none of them worked, so I assume its the controller.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
donald smith, I just checked the diagram and I can not seem to find a fuse per se. I would disassemble the console and take a look at the capacitors as well as all traces. There is always a possibility of dried out and broken components as well as bug (the entomology kind) damage. I attached an image which does have the values attached to it, this may help you to check components with a multimeter. Hope this helps, good luck
2600 Motherboard silk screen
2600 Chanel 3 Switchboard Schematic
这个答案有帮助吗?
得分 1
添加一条评论
Several possibilities exist for this. The first is that the power supply itself is bad. These have a high failure rate now because of the age. The other possibility is that the power jack or power switch is loose, and needs the solder reflowed. The solder on these boards is weak from age, most units I work on all need reflow. There are also a few capacitors on these that need replaced. This usually won't cause it to completely be dead though, most likely you would see partial static, blank screen, or color bars. Make sure the cartridge slot and cartridges are clean. Nothing more than rubbing alcohol is needed to clean them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
donald smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,528
