跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
317 个问题 查看全部
Ipad 2 not charging after digitizer replacement. Any ideas?
I've just replaced the front panel and digitiser on an iPad 2 Wifi. I've been using it for a few hours and battery life has depleted at its usual rate. When plugging it into the mains or laptop it doesn't show as charging or hold any charge.
I've tried turning off and resetting but have been unsuccessful.
Has anyone else had a similar problem or is able to give me any advice?
I'll be opening her up again tomorrow to have a closer inspection.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
Many thanks for the replies.
It was indeed a damaged charging dock connector. Fortunately it was a £3.99 fix.
Thanks again
添加一条评论
4个回答
已选择的解决方案
Hi
As mentioned above if you are using a metal spudger to get the old screen off, you may have gone through the charging dock cable, however before removing this new digitizer, please ensure you try another charger in case the current one is faulty
Regards
Ali
这个答案有帮助吗?
按维修分数 0
添加一条评论
最有帮助的答案
see if you disconnected charging port cable or damaged it by any chance
这个答案有帮助吗?
按维修分数 1
添加一条评论
cheak the power cable if there is any small crack , when you open the digitizer maybe you dameg it it is located near the volume switch
这个答案有帮助吗?
按维修分数 0
添加一条评论
hiya i wonderd if you can help me i have took the digitilzer off a ipad 2 wifi and the plastic bits where the digilizer cable goes in has come off n how do i put them bk on or does it affect it without them please can you email me on fozzy58@outlook.com
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Robo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 3,269
