跳转到主内容
加入维修社区 - 创建账户
27英寸显示屏,分辨率为 2560 x 1440 像素 Thunderbolt 与 MagSafe 线缆连接
blank screen 27 inch thunderbolt
my display has a blank screen.It powers up
what could i do????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Try it with another Mac with a Thunderbolt port first. That failing, call AppleCare.
这个答案有帮助吗?
得分 1
添加一条评论
I have the exact same problem. When connected to my laptop, the laptop shows that the display is plugged in and working but there is no display, no back-light, nothing.
I am solving it by replacing the video controller main board inside the display itself. I know my particular problem is due to a bad ribbon cable connector on the main board. This particular ribbon cable carries all the video data to the LCD display.
If a replacment board isn’t available here:
[关联产品丢失或禁用: IF359-000]
A replacement (re-manufactured) board can usually be found on eBay for between $50 to $200 depending on seller and location.
This guide goes over how to remove the main board. It’s actually a guide to replace the Mini Display Port/Magsafe Cable, but doing that requires removal of the main board so the guide still works.
Apple Thunderbolt Display Thunderbolt & MagSafe Cable Replacement
这个答案有帮助吗?
得分 1
1条评论:
I wish to note that I just conducted the repair exactly as I noted above and my display is back to perfect working condition!
完成的
添加一条评论
添加你的答案
frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 2,408
